how hard
Old Apr 12, 2005 | 10:48 AM
5.0mustang5speed's Avatar
5.0mustang5speed
I ♥ Acer
Default how hard
how hard do you stick shift guys leave the line....at what rpm?
Old Apr 12, 2005 | 11:18 AM
Mune's Avatar
Mune
Default RE: how hard
That all depends on some things. If I am trying to be good and not make a lot of noise or attract to much attention I shift at about 2200-2500, if I am in the mood to hall a bit I may get up to 3000 or even 3500. I sort of learned to drive the stang on my own so I just go by the sound and feel of the car. But that is with a v6 too so I do not know if it variates any between v6 and v8.
Old Apr 12, 2005 | 11:39 AM
Marty256's Avatar
Marty256
Depends on what you want to do and what kind of rubber you're running. If I want to light up the tires at a light I'll launch at about three grand on stock rubber. If I'm at the track looking for a consistant ETs I'll launch at around 1500 while ridding the clutch until about sixty feet then let out the clutch and go like *ell. If you're running slicks and a decent rear axle ratio you can launch at two or three grand and dump the clutch. Experiment. No two cars launch exactly the same. Tire pressure plays a role also. Hope this info helps.
Old Apr 12, 2005 | 01:13 PM
nanaki's Avatar
nanaki
Retired MF Moderator
riding the clutch isn't good. i shift between 2000-2500rpm when i'm just normally driving. i shift at about 5000 when i wanna prove a point.
Old Apr 12, 2005 | 01:50 PM
vfast's Avatar
vfast
I ♥ Acer
marty..where did you get my avatar?
on lil street racing I leave around 3k on slicks in the 4k range
Old Apr 12, 2005 | 08:34 PM
5.0mustang5speed
I ♥ Acer
im thinking 5000 rpm...with slicks...and 4.10;s
Old Apr 12, 2005 | 09:57 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
I know it's not a Stang but I leave at 3500-4000 rpm on my drag radials.
Matt's 95 Stang
Oct 5, 2015 07:16 AM
UrS4
Oct 3, 2015 06:23 AM
guitarman376
Sep 30, 2015 05:54 PM
1996cobraconvertible
SVT Forums
Sep 30, 2015 02:01 PM
wraith777
Sep 28, 2015 10:49 AM
