Bad brakes?
Old May 4, 2005 | 02:43 AM
Chris C's Avatar
Chris C
Default RE: Bad brakes?
Since its a 94 you should have disk out back also. Sounds like you need new rotors and pads all around. If its a grinding sound your rotors are shot Im pretty sure. Brakes on mustangs are pretty straight forward to do if you know how to do brakes LOL. If you are not sure get someone to help you or get them done. Brakes are too improtant to just wing it.
Old May 4, 2005 | 10:04 AM
babygurl2000's Avatar
babygurl2000
I ♥ Acer
your brakes are going to be expensive now. all new rotors and pads and shoes.
hope you have the special tools to do them with..
good luck!
Old May 4, 2005 | 10:32 AM
DIVER8374's Avatar
DIVER8374
ORIGINAL: babygurl2000
good luck!
^^^ What special tools are you refering too? I have done brakes a bunch of times on different cars/truck and never need any special tools.
To get your piston pushed back in, put you pad on then take a big "c" clamp and put it on the outside of the caliperand on th inside on the pad. (center it over your piston) Then all you need to do is turn it so the pad pushes the piston back in. It is that easy.
Old May 4, 2005 | 09:10 PM
Chris C's Avatar
Chris C
Hey diver8374 Im not sure about your 2001 brakes but some mustang brakes do take special tools to get done. I put rear 94GT axels and brakes on my 93GT. When I went to replace the pads I tried the old C clamp on the caliper on the pass side and it would not go in. Since the brakes were in pretty bad shape I thought the caliper was shot so i get a new one. Well when I get to the driver side same thing. No way both were bad so I call my buddy who works at ford and he told me they take a special tool to compress the caliper. Its a peice that goes on a 3/8 ratchet and you "screw" the caliper in. So whenever you go to replace your brakes if they dont compress with a c clamp you might need one also. You can get the tool at napa(even though it dont fit prefect) for like 10$. Would have save me alot of time and money if I had known.
Old May 5, 2005 | 12:02 AM
babygurl2000
I ♥ Acer
ORIGINAL: DIVER8374
good luck!
putting them springs back on requires a special tool for a much easier job.
follow me here?
mtgldr
Feb 3, 2024 09:00 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
DoctorScary
Sep 9, 2015 07:53 AM
Sep 8, 2015 11:50 AM
