Bad brakes?
Old Apr 12, 2005 | 02:56 PM
94droptop's Avatar
94droptop
Default Bad brakes?
I have bad brake i hear a nasty noise from one side and i know the rotors need to be replaced. what else should i replace front and back?
Old Apr 12, 2005 | 03:26 PM
kubball2005's Avatar
kubball2005
Default RE: Bad brakes?
ORIGINAL: 94droptop
What does this nasty noise sound like? Squeaking? Metal on metal contact?
Old Apr 12, 2005 | 04:02 PM
94droptop's Avatar
94droptop
a grinding sound my brakes arent that great at all i need to really puch them to stop. i know pretty sad but i figured i can replace the stuff myself and it will be all good so what is there rotors pads? anything else it is a 94 v6
Old Apr 12, 2005 | 04:37 PM
94droptop's Avatar
94droptop
a little help anyone?
Old Apr 12, 2005 | 08:02 PM
vfast's Avatar
vfast
I ♥ Acer
refer to your chilton manual
Old Apr 12, 2005 | 08:06 PM
Mune's Avatar
Mune
Dude, how about some punctuation ^. It took me three times to figure it out, I think I need some caffeine. Ok, you definently need to change the pads, also the brake rotors need to be smoothed back out or it is senseless to change the pads. I forgot what that process is called (calipering?) but your local auto parts store can usually do that no prob. Here is a lonk with a sort of checklist on it for ya. Good luck.
http://www.thepartsbin.com/change-brake-pads.html
Old Apr 12, 2005 | 08:13 PM
89stanglx's Avatar
89stanglx
Most likely your rotors wont be able to be turned down enough to smooth them out without going past there minimum thickness. I would replace the front rotors and pads. Pull off your back drums and check them, but back brakes last a long time before pads need replacing because most of the stopping power is in the front.
Old Apr 13, 2005 | 12:53 AM
94droptop's Avatar
94droptop
i know that the front rotors are cant be machined without going past minimum. I will replace them, how hard is that? i also have a noise coming out of the back rear , what is there to replace back there? thanks for the replies. how hard is this to do?
ps sorry bout the pun.ctuatuon
Old Apr 13, 2005 | 07:11 PM
94droptop's Avatar
94droptop
[sm=feedback.gif]
Old May 4, 2005 | 02:25 AM
mustangmadness's Avatar
mustangmadness
Yo, I just got some brakes i'm putting on my mustang, and I can't get the brake pistin to go back in after i took off the old brakes, it's just stock at where the old ones were at, please let me know what i can do to get them in. O and it's called getting your rotors Turned. please let me know anyone.....
