Truck mounted battery, cut off question.
Old Mar 29, 2008 | 04:31 AM
Jfsram's Avatar
Jfsram
Default Truck mounted battery, cut off question.
I have a 93 coupe with the battery mounted in the truck. The positive lead runs through a switch under the bumper.
NHRA track rules state the engine must die when the switch is thrown. I cheated tech twice by leaving the lights and rear window defrost on. The load is high enough to force the engine to die without the batteries help but regardless what is the easiest way to be legal?
Old Mar 29, 2008 | 11:27 AM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Default RE: Truck mounted battery, cut off question.
Does this help you?
http://www.timskelton.com/lightning/...y_relocate.htm
Old Mar 29, 2008 | 12:14 PM
GreyStang's Avatar
GreyStang
Put another switch under the hood that disconnects the alternator power. When racing turn the alternator switch off first, the ignition system will then be 100% powered by the battery.
Nov 18, 2015 01:34 PM
piotrek53
Oct 13, 2015 06:54 PM
jessicarabbit
Sep 25, 2015 12:41 PM
stark777
Sep 21, 2015 12:46 PM
Sep 17, 2015 07:57 PM
