leaking fuel pump??????
Old Mar 29, 2008 | 09:00 AM
capri_83's Avatar
capri_83
Default leaking fuel pump??????
I just installed a new Holley Black fuel pump in my car and on start up I check for leaks and found at the bottom of the pump there is a brass plug and a small machined hole in the body(not in the motor section). this is leaking a fair bit of fuel, I have let the car run for some time and it has slowed down but still slight wetness........any help would be great thanks
Old Mar 31, 2008 | 04:05 PM
capri_83's Avatar
capri_83
Default RE: leaking fuel pump??????
just in case anyone else runs in to this problem, I phoned holley and they say it's a pee hole to tell you if the seal between the rotor and motor is leaking...... at this point the leak has stopped...... they think the seal was just dried up ...
Oct 26, 2015 05:01 PM
Meystang
Sep 25, 2015 04:05 PM
pimp2303
Sep 17, 2015 08:45 PM
SteelerNation82
Sep 16, 2015 07:11 AM
rksnow1
Sep 14, 2015 08:46 PM
