tpms ... mod ?
Old Apr 5, 2008 | 09:33 PM
jake3's Avatar
jake3
Default tpms ... mod ?
putting thesensors in the spare tire??? will this work ....
Old Apr 8, 2008 | 04:38 PM
1367mustang's Avatar
1367mustang
Default RE: tpms ... mod ?
Hmmmmmmmmm
Assume you changed rims !!!
You can use the sensors as long as you get new straps.$40.00
Regards
Brian
Old Apr 8, 2008 | 05:24 PM
golden_eye's Avatar
golden_eye
If you have a donut spare then it may not work as they usually have a much higher pressure than normal tires (~60 psi). I've seen a little trick where someone contructed a tube out of PVC pipe and installed a nipple (hehe [8D]) on one end.They put the sensors inside andused a pump to pressurize it to about 30 psi and stuffed it in the trunk or the back seat or somewhere.
Silly technology, it's not like you can't see when your tires are low .
CS2007
Jun 25, 2019 09:45 PM
UrS4
Oct 3, 2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
TimeLord101
Oct 1, 2015 06:40 AM
CS2007
Florida Regional Chapter
Sep 29, 2015 12:06 PM
