tires psi
Old Apr 11, 2008 | 09:29 PM
MAKDAGR8's Avatar
MAKDAGR8
Default tires psi
what psi are my tire supposed to be at? is it less when u race or how does that work
Old Apr 12, 2008 | 02:40 PM
Jfsram's Avatar
Jfsram
Default RE: tires psi
Stock is 30 psi. As for racing you want a flat of a footprint as possible. Experiment is the only answer here.
Some slicks and soft racing tires want single digits like 6 or 8 psi.
Hard low profile street tires will want alot more.
Old Apr 13, 2008 | 08:18 AM
Tha Boss's Avatar
Tha Boss
Some people run slicks at different psi for different reasons but most are usually low. I run slicks at about 12-14 psi.
Old Apr 13, 2008 | 10:58 AM
jmonty's Avatar
jmonty
i run mine at 35 because that is what the little sticker on the inside of the drivers door frame says, but my tires say max is 44..
Old Apr 13, 2008 | 04:58 PM
Mjaga251's Avatar
Mjaga251
I'm currently running at 40, which is high. I guess I'd say normal is around 35, depending on your driving habits, and preferred has mileage..
Old Apr 13, 2008 | 10:39 PM
sfi's Avatar
sfi
I run 36 lbs, thats whay BFG told me optimal performance/gas miliage was. I let me rear down to 28 when I go to the strip
Old Apr 16, 2008 | 05:50 AM
MikeIt69's Avatar
MikeIt69
Mostly test and tune dude, on a day off play around with adding or subtracting pressure from the stock spec of most regular tires (32psi). The less pressure you have in your tires the more expansion will take place, and in most cases more expansion = more traction.
You only need to adjust the rear wheel pressure on Mustangs because the rear is where the traction is needed obviously...
For the most part I would leave the pressure at stock specs unless you are running slicks for the 1/4 mile, I think slicks have a minimum pressure of 5-6 psi but im not 100% sure of that.
Old Apr 20, 2008 | 11:37 PM
ronsfun96gt's Avatar
ronsfun96gt
Read on the side of the tire. It will tell you. Also check your air pressure when the tires are cold
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
TCStangerv6
Oct 11, 2015 05:57 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
