Now what next?
Old Apr 17, 2005 | 12:53 AM
92hatchLX's Avatar
92hatchLX
Default Now what next?
I got my exhaust done today, and I did NOT lose any power, I gained gas mileage and a tiny bit of noticable power. But what should I go for next? I was thinking some 1.7:1 roller rockers. Anyone care to give there opinion?
BTW, getting you're mufflers removed and replaced with pipe does not sound "untuned".
Old Apr 17, 2005 | 01:28 AM
Kyle83's Avatar
Kyle83
Default RE: Now what next?
if you dont have it already, get a cold air intake, or either get a better camshaft (which takes a bit of work and money), or if your carburated like i am, switch to a better carburator, like a 750 or better
Old Apr 17, 2005 | 01:50 AM
92hatchLX's Avatar
92hatchLX
I've removed all of my air silencer, and I think that I'm just going to stick with that and a K&N filter. A cam sounds good though and I know how to do those. I'm thinking the B-303 cam would sound good and perform good.
Old Apr 17, 2005 | 11:07 AM
stanglx2002's Avatar
stanglx2002
i would say a bigger MAF, TB, and a new intake next
Old Apr 17, 2005 | 02:40 PM
86inworks's Avatar
86inworks
change the gears if you haven't done so already maybe to a 3.73 or 4.10
Old Apr 17, 2005 | 03:12 PM
92hatchLX's Avatar
92hatchLX
What size MAF and throttle body should I get and who makes the best. Since I can only afford one at a time, which one should I get first?
Old Apr 17, 2005 | 04:43 PM
sastangman's Avatar
sastangman
if you really want to feel a difference change the gears to 3.73 or 4.10. next go with a
fenderwell cold air intake,75mm bullet mass air meter,65mm bbk tb,24 lbs injectors
to match the mass air meter.
Old Apr 17, 2005 | 05:15 PM
Aliate X's Avatar
Aliate X
I ♥ Acer
ORIGINAL: 1991_5.0_Convertible
It wont sound untuned, just sound like crap.
Old Apr 17, 2005 | 06:56 PM
Predator's Avatar
Predator
After a long discussion a few months ago, it was agreed upon that the size of the MAF does not matter as long as its bigger than the tb. So what I plan on doing is gettting the 83mm maf (my cold air is 83mm in the front, then goes down to 75mm) and getting a 70mm tb.
Basically the size of the tb is what makes you gain/lose hp based on your mods. If you aren't making alot of power, a 73+mm tb will hurt your lower hp but help you in the top end, but really how many people keep their mustangs above 3000 rpm consistantly to notice that little gain. So since you already have some mods, and it looks like you are going to do more, I'd advise the 70mm tb (to keep you open for more mods later) and a larger maf.
Cold air intake is also a good choice, but if you just want the K&N filter...go ahead and take the import way out (I'm gonna take flak for that one most likely).
You could also look into MSD, from what I've heard, its one of the best mods you can do to have a reliable performance driven engine. Just talk to the people who have done it.
Old Apr 17, 2005 | 09:18 PM
92hatchLX's Avatar
92hatchLX
Man, Aliate x, I wish I had something to record sound just for you. Have you ever heard a 5.0 with the same exhaust set up as mine? And btw what exactly sounds good to you?
