Installing your own window tint.
Old Apr 15, 2008 | 06:30 PM
acascianelli's Avatar
acascianelli
Default Installing your own window tint.
Just wondering what are peoples opinions on installing your own window tint. I have a S197 with no upper door frame and the window drops down a little when I open the door, will this be an issue?
Old Apr 15, 2008 | 06:36 PM
burnout2003's Avatar
burnout2003
Default RE: Installing your own window tint.
im might becase itmight peel up the tint, but i wouldnt worry about it i got tint done and role down the window to pay a ts soll and its still fine so dont sweat it
also get it professionally done its worth it
Old Apr 15, 2008 | 07:16 PM
j3rry's Avatar
j3rry
as long as get all air bubbles out and water out should be fine . if ur gonna tint them make sure its pretty nice out or in warm garage sht can be a btch to work then when cold out lol .
Old Apr 15, 2008 | 08:03 PM
95greengt's Avatar
95greengt
you can do it yourself just take your time and make sure its pretty warm out but if you want it to look perfect the first time go get it done professionally it might save you a headache
Old Apr 15, 2008 | 10:09 PM
YAYITSJEWDAY87's Avatar
YAYITSJEWDAY87
i would just pay some one it should be around 150 with a lifetime warranty on it
Old Apr 16, 2008 | 05:20 AM
MikeIt69's Avatar
MikeIt69
Got my windows professionally tinted and it costed $280 Canadian. Legal 15% on all windows and rear.
Check your rear window along the top edge for dot matrix, if you have it you may need a heat gun to get the tint to stick to itso itwont be 1 massive air bubble. If you have dot matrix, tint the rear window normally and wait for the tint to settle for about 2-3 months minimum before carefully heating it.
If your doing it yourself have buckets of soapy water to spare, along with 10-20 dry rags. Make sure windows are up and peal back the rubber seal on the inner side of the widows so you dont get a white line along the bottoms of the windows.
Wait for a sunny day to do the tint, start in the morning if you can so when you finish the sunn will help the curing stage go faster. Do NOT roll down your windows for minimum of 3 days, most companies recommend 5 days or the warranty is void. Good luck and post pics if you do it.
Old Apr 16, 2008 | 06:28 AM
GreyStang's Avatar
GreyStang
Tinting glass yourselfcan be a royalpain in the @ss [:'(]you've got to be very CLEAN working on it or you'll get lint & stuff stuck between the glass & the tint. Remember too that thewindow tint material DOES NOT STRETCHso if the glass has a compound curve then you'll have to do it using many individual pieces. If you don't know that glass has a compound curve (most do) put a straight edge like a ruler on the glass. If the ruler sits FLAT on it then it's easier to tint
Old Apr 16, 2008 | 05:20 PM
MooseStang88's Avatar
MooseStang88
I would suggest you have a professional do it. you can, it just takes time and patience.
Old Apr 16, 2008 | 05:51 PM
ExtrmZ's Avatar
ExtrmZ
what are some average costs on professional work?
Old Apr 16, 2008 | 05:54 PM
95greengt's Avatar
95greengt
130-150 depending on where you go
mtgldr
Feb 3, 2024 09:00 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
TimeLord101
Sep 4, 2015 09:27 AM
