Gas cap
Old Apr 16, 2008 | 09:12 PM
MustangMike2001's Avatar
MustangMike2001
Default Gas cap
Since I bought my car the gas cap has only allowed about a quarter turn before it stops and it doesn't click or anything. I'm not sure if that's just how ours work or not but I've been having my gas cap light come on and ses codes related to evap leaks. I bought a new gas cap to see if that changed anything but it does exactly the same as the other one. Any ideas?
Old Apr 16, 2008 | 09:21 PM
MikeIt69's Avatar
MikeIt69
Default RE: Gas cap
Has the gas tank been replaced?
Look closely when you take the cap off to see if there are threads that go below the surface the cap sits flush on. If there are try pulling that neck out but dont force it, if thats not working, try carefully pushing the gas tank up on the side of the gas cap but dont force it.
Old Apr 16, 2008 | 09:28 PM
MustangMike2001
Default RE: Gas cap
The neck sticks out as far as it possibly can. The cap just won't turn.
Old Apr 16, 2008 | 09:38 PM
MikeIt69's Avatar
MikeIt69
Default RE: Gas cap
Got me then, buy a new cap?
Old Apr 16, 2008 | 11:40 PM
MustangMike2001
Default RE: Gas cap
I did..
Old Apr 16, 2008 | 11:49 PM
MikeIt69's Avatar
MikeIt69
Default RE: Gas cap
Bought the wrong cap then.
Old Apr 16, 2008 | 11:55 PM
MustangMike2001
Default RE: Gas cap
uh no I didn't. Anyone that has a clue wanna chime in? please
Old Apr 17, 2008 | 01:05 AM
MikeIt69's Avatar
MikeIt69
Default RE: Gas cap
Ok, if you have 2 stock parts (filler neck and gas cap both made by ford for mustangs) then there will be no problem at all. So you have something aftermarket whether its the filler neck or gas cap for the threads not to be lining up...
If your filler neck is the original go to a ford dealer and buy a gas cap, if your newgas cap ismade by ford for mustangsand your filler neck is the problem then you bought the wrong cap...
Its most likely the filler neck, buy every gas cap on the market and try them all until you find 1 that fits and return the others.
Did this help or are you still confused?
4cylinderplus2
Oct 9, 2020 07:45 PM
Sixer4Life
Oct 12, 2015 04:26 AM
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
