INSTALLING A HOOD
Old Apr 20, 2005 | 12:42 PM
frank28's Avatar
frank28
Default INSTALLING A HOOD
What's the best way to install a hood on a latemodel mustang. It looks like there are only four bolts that have to be unscrewed. Is that correct?
Old Apr 20, 2005 | 01:20 PM
Grandmaster's Avatar
Grandmaster
Default RE: INSTALLING A HOOD
Yeah, just make sure you have a couple people to help hold it, Because you dont want to ding it.
Unscrew the bolts, and then just srew the new one in, easy as pie.
Old Apr 20, 2005 | 01:52 PM
roundman's Avatar
roundman
the trick is getting the new hood aligned with the bodywork around it so it looks right and doesn't hit the adjacent body panels and latches properly.
Old Apr 20, 2005 | 02:40 PM
Djs94stang's Avatar
Djs94stang
Yeah 3 people is the best to do the job. Make sure when you bolt it up you lower it very slowly to make sure the alignment is right. Take your time on it and it will be easy.
Old Apr 20, 2005 | 06:22 PM
MikeHawke's Avatar
MikeHawke
Retired MF Moderator
yeah, alignment is a bitch. If you are only taking the hood off for bodywork or whatever and putting the exact same hood back on, it's a good idea to mark the outline of the hinges on the hood itself before removal.
StalkerGT
Sep 25, 2015 02:41 PM
cbird1177711
Sep 2, 2015 04:12 PM
