Driveshaft rub
Old Apr 28, 2008 | 11:56 AM
dr125m's Avatar
dr125m
Default Driveshaft rub
My 98 gt has tokico illuminas and eibach sport springs installed. Also have an aluminum driveshaft.. Whenever im on the gas hard andrear is squating my drive shaft rubs the bottom of the tunnel. actuall theres a bracket to hold a couple cables there that its rubbing on and taking a bug chuck out of the shaft. couldthis be fixed with some bigger tires?( i have 245's) or should i change out the springs and shocks in the back? any other fixes?
Old Apr 28, 2008 | 06:25 PM
USMC1775's Avatar
USMC1775
Default RE: Driveshaft rub
Its the E-brake bracket. You have to either bend the bracket back, or get a smaller ds. You could try getting stiffer shocks, but I thought those Tokikos were the ****. My buddy had same prob, but a 3/4" notch all the way around his new ds.[:@]
Old May 2, 2008 | 06:23 AM
Jfsram's Avatar
Jfsram
The pinion angle should be nose down, relative to the driveshaft. Check it out.
Old May 3, 2008 | 11:32 AM
jeffro22's Avatar
jeffro22
you can screw or rivet the ebrake cable to the trans tunnel,
mtgldr
Feb 3, 2024 09:00 PM
baddog671
Jul 26, 2016 01:20 PM
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
ccdguy
Sep 19, 2015 05:20 PM
