Stalling problem after warmed up
Well it's not a Mustang...not even a Ford.....it's a Dodge....Dodge Ram. I figured someone on here must have one of these.... It's an automatic 1998 Dodge Ram 2500, Regular Cab, 4WD 5.9L Gas. After a few minutes of it getting warmed up it will flat out STALL and not want to stay running at all. In gear, in park, if your foot is not on the gas it will stall. You have to power brake it in order to move, 3 point turn, back up and then drive forward or even park it. What the hell is the problem? All the sensors/plugs hooked up to the throttle body have been replace. It does not throw any check engine lights at all. What do you all think?
ORIGINAL: jwog666
have seen it before its usually the idle air controll motor (iac). it wont throw a code for this.
trashxtrash
Sep 20, 2015 10:49 PM
TfcCDR
Sep 14, 2015 12:08 PM
tramphardrocker
Sep 13, 2015 08:56 PM
