oil pump gasket
Old May 10, 2008 | 04:03 PM
ExtrmZ's Avatar
ExtrmZ
Default oil pump gasket
is there a gasket that goes in between the oil pump and the block?
Old May 10, 2008 | 05:39 PM
ExtrmZ's Avatar
ExtrmZ
Default RE: oil pump gasket
the pump came with a gasket that hook the pick-up tube to the pump itself. i know that some chevy's would not use a gasket that hooks the pump to the block, is this the same way?
Old May 10, 2008 | 06:01 PM
ALMOST STOCK's Avatar
ALMOST STOCK
Between the Pick-up tube and the Oil Pump -- Yes
Between the Block andOil Pump-- No
Old May 10, 2008 | 07:22 PM
PJC Racing's Avatar
PJC Racing
ORIGINAL: ALMOST STOCK
Incorrect.
There is a gasket for both.
Old May 10, 2008 | 07:51 PM
ExtrmZ's Avatar
ExtrmZ
so which one is it?
Old May 10, 2008 | 09:50 PM
PJC Racing's Avatar
PJC Racing
I have torn down and assemble a few and all have had the pump to block gasket. Think about it, it makes no sence to have one on the pick up tube and not the block.
Old May 10, 2008 | 10:19 PM
ExtrmZ's Avatar
ExtrmZ
did they come with the pump?
Old May 10, 2008 | 10:20 PM
ALMOST STOCK
And I telling you what the Ford Shop Manual says.
Old May 10, 2008 | 10:23 PM
.boB's Avatar
.boB
http://i13.photobucket.com/albums/a2...umpGasket2.jpg
This is a scan right out of the factory service manual. It clearly shows a gasket in both places. It's a pressurized passage, of course it has a seal.
Old May 11, 2008 | 11:18 AM
ExtrmZ's Avatar
ExtrmZ
there was not any leftovergasket on the old block or old oil pump... which makes me believe that there is no gasket supposed to be there
