93 F-150 HELP!!!
Old May 14, 2008 | 05:21 PM
5.0 85 GT's Avatar
5.0 85 GT
Default 93 F-150 HELP!!!
HI, i have a 93 f150 5spd with the 4.9 I-6...my trucks brake lights dont work and the abs light is on, so i replaced the fuses about an hour after i drove the truck 40 min away and 40 min back....i took out all the fuses, the battery was connected, and i put in each new fuse..then i went to turn the truck over and it wont start...no clicking, no radio no nothing...i hope its not the starter..but i think its a security issue..like it thinks im stealing the truck but not sure...please help i need it running....it will start if i popstart it and runs perfect..until i turn it off and go to restart it nothing happens...le tme know what u think
Old May 14, 2008 | 05:59 PM
mrdeep2001's Avatar
mrdeep2001
Default RE: 93 F-150 HELP!!!
maybe you missed a fuse[&:]
Old May 14, 2008 | 06:08 PM
5.0 85 GT's Avatar
5.0 85 GT
ya its possible...anyone else think anything??
Old May 14, 2008 | 06:13 PM
mrdeep2001's Avatar
mrdeep2001
could be a bunch of things, starter relay, ignition switch, I can keep naming parts but it wont get anywhere.
You said it is not doing anything(no cranking?)
I would try to see if you are getting power to the starter and starter relay
Old May 14, 2008 | 06:15 PM
5.0 85 GT's Avatar
5.0 85 GT
ya no cranking at all....u just see the speedo and amp guae surge qucik..doesnt make any sense...it ran and started beautifully just yesterday
Old May 14, 2008 | 09:46 PM
golden_eye's Avatar
golden_eye
Is there a clicking noise coming from the hood? Could be a starter solenoid. Check the battery cables too. I had the one running to the starter corrode through and break on mine so it would click the solenoid but not turn the starter.
stark777
Sep 21, 2015 12:46 PM
95_302_StangMan
May 18, 2005 05:48 PM
UT04GT
43
Apr 24, 2005 06:49 PM
