simple one wire dizzy chevy question
Old May 16, 2008 | 09:41 AM
aode08's Avatar
aode08
Default simple one wire dizzy chevy question
working on a 1969 camaro 350 4bbl mechanical carb, mechanical dizzy, with vac advance and 1 black wire coming from it.
the coil is a cylinder with one screw+ the other negative -
the distributor has one black wire(old points type mechanical) .
I got number one set TDC, how do I wire this simple setup, we are starting from scratch and the coil is new(2 of them incase one is bad-autozone brand).
I connected both screws directly to battery with thin wire to see if I got spark, none came.
So someone tell me what im doing wrong here lol
Old May 16, 2008 | 10:50 AM
ryan1994mustang's Avatar
ryan1994mustang
Default RE: simple one wire dizzy chevy question
you are not posting pictures of said 69 camaro....sorry cant really be of help with the distributor issue, but wouldnt mind seeing the car, good lukc with the fix though.
Old May 18, 2008 | 11:26 PM
Jfsram's Avatar
Jfsram
Key on power will go to the POS side of the coil. Must be hot while running and during cranking.
The one black wire coming from the distributor goes to the points. This gives you ground 8 times per revolution. That goes to NEG on the coil.
Old May 21, 2008 | 12:10 PM
aode08's Avatar
aode08
i took off the cap, the black wire goes to the points and has a single black wire coming off the dizzy, where does this goe? to ground? to the coil - etc.
and how is the coil ground
Old May 21, 2008 | 12:11 PM
aode08's Avatar
aode08
k thanks i get it
Old May 21, 2008 | 03:12 PM
akp20032004's Avatar
akp20032004
Ha Ha this kid a couple days ago totalled his dad's 69 corvette. He tried to fish tail it and lost control and hit a metro bus sign and totalled it pretty much. It's fixable but it's going to cost a lot of money!!
Old May 22, 2008 | 12:27 PM
Jfsram's Avatar
Jfsram
ORIGINAL: akp20032004
What does this have to do with this thread?
In order for a coil to fire. It needs power at the positive and ground is broken.
So connect the pos to key on power. It's oftena resistor wire or run through a ballast resistor.
Must be hot during cranking and run.
The other wire goes to the points. It will be open and closed 8 times per revolution. Often paralleled with a condenser.
For what it's worth. Throw that system out and get either an GM HEI, Pertronix or MSD set up.
2007StangV6
Jan 28, 2016 06:09 PM
Nov 10, 2015 11:39 AM
Luke9222
Sep 4, 2015 06:46 AM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
