Old Gas
Old May 20, 2008 | 10:19 AM
Wildwisc's Avatar
Wildwisc
Default Old Gas
I have a '95 Mustang that has been sitting for over a year with a three quarters full tank of gas. I just pulled the old engine and am in the process of installing the new one. Should I drain the old gas or would it be alright to treat it with Pri-G and use it?
Old May 20, 2008 | 10:55 AM
GreyStang's Avatar
GreyStang
Default RE: Old Gas
One year old gas isn't the end of the world,, it should still be OK so long as you just drive conservatively with it until you refill the tank with new gas.
..the bigger concern might be thatthe tank was only 3/4 full for a year.. you might have picked up some water condensation in that empty space that woulda screwed up the gas even more. Personally I'd drain it out.
Old May 20, 2008 | 02:52 PM
Stepman's Avatar
Stepman
Default RE: Old Gas
Drain it. Being that old, it has probably turned into varnish by now. If you run tight clearances with new engine, you may stick a valve.
4cylinderplus2
Oct 9, 2020 07:45 PM
Sixer4Life
Oct 12, 2015 04:26 AM
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
