Heating Question
Old Apr 26, 2005 | 07:03 PM
Grandmaster's Avatar
Grandmaster
Default Heating Question
When I turn my heater out it blows warm moist air which makes the windows fug pretty bad when its raining or cold out. What could cause it and how do i fix it? Also all the door locks dont work, what could i do about that?
Old Apr 26, 2005 | 07:08 PM
Djs94stang's Avatar
Djs94stang
Default RE: Heating Question
The heater core could be leaking....
The door locks....could be a fuse...maybe unplugged if someone had the door panels off. You need to start with the fuse box though.
Old Apr 26, 2005 | 07:19 PM
Grandmaster
Heater core leaking? Wouldnt it smell like radiator fluid though/
No i mean i can't lock the doors from the outside with my keys. It has power locks.
Old Apr 26, 2005 | 08:03 PM
roundman's Avatar
roundman
it could be the drain hose from the AC evaporator coil is stopped up and the water is being held back up in the heater/AC box. check for the drain line down low on the firewall on the passenger side and see if it's plugged, you might be able to run a stiff wire up in it to clear it out. if it is the heater core leaking, then it should definitely smell like antifreeze, especially when it's hot.
PaulH2
20
Jan 31, 2016 09:48 AM
treesloth
Sep 28, 2015 07:03 AM
Ipaman
Sep 22, 2015 07:01 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
Art161
Sep 9, 2015 10:33 AM
