weird transmission
Old May 27, 2008 | 01:59 PM
Mustang007's Avatar
Mustang007
Default weird transmission
Hi guys, I'm having porblems with my transmission. I was driving and all went like usual. I parked the car and got in to eat and when I came back I couldn't put my transmission in drive (automatic). I check under the car and there was liquid. I checked and it was only water. But after pumping the brake a couple of time I was able to put it in drive(I couldn't press the button that makes the stick shift budge)l still havethatproblem. But when i'm in drive and I go reverse there's no problem there. It's only when I need to get the car running. The transmission looks good I have no problems with it when i'm driving. It's really when I want to stuck it out of park (P). Any have ideas??
Old May 27, 2008 | 08:55 PM
VASSAGO's Avatar
VASSAGO
Banned
Default RE: weird transmission
must be a aod!
Old May 27, 2008 | 09:22 PM
Mustang007's Avatar
Mustang007
what's an aod??
Old May 28, 2008 | 12:55 AM
kazuya's Avatar
kazuya
Hi, Maybe its an Overdrive? A bad temp. sensor can do that. If the engine thinks the temp. is below 20 degrees it won't let the transmission go into overdrive. It's possibly a sticking solenoid but you aren't giving us enough info. Anything else we need to know (was the car ever in a flood)?
Old May 28, 2008 | 01:39 AM
Stepman's Avatar
Stepman
sounds a lot like a brake interlock gone bad. What year is this? Does it only stick in Park?
4cylinderplus2
Oct 9, 2020 07:45 PM
b8checker
Oct 8, 2015 12:55 PM
mungodrums
Sep 28, 2015 10:54 PM
wraith777
Sep 28, 2015 10:49 AM
