help with 351 c tune
Old Jun 3, 2008 | 04:49 PM
miketami's Avatar
miketami
Default help with 351 c tune
I have been fighting this build for a couple months. any help would be great. here is what I have
70 mach 1 351 c .30 over
roller rocker cam 240lift 560 duration hydr roller
headers 2.5 exhaust 2 stage flowmasters
msd ign
holly 750 mech 2nd
Timing is now at 18 deg lighest msd springs, smallest bushing. 36 deg total
Car still leaves the line like it has a trailer behind it, and sputters if I get into the 4 barrel hard.
Any advise would be great!
Old Jun 3, 2008 | 10:21 PM
67mustang302's Avatar
67mustang302
Default RE: help with 351 c tune
Most likely accelerator pump. And what heads? 750cfm may even be a bit much, especially a mechanical 2ndary carb, and especially depending on your gearing and vehicle weight. Chances are you'll just need to work hard at tuning both the pumps.
Old Jun 4, 2008 | 06:29 AM
miketami's Avatar
miketami
Thanks for the reply.The car is a 70 mach 1 (I will have to check weight)I am running the stock 4v heads. 350 gears in the rear. I started with a holly 650 and it seamed to be starving. I put a 750 proform center in the 650.
should I have gone with vacume 2ndry?
Old Jun 4, 2008 | 09:31 PM
67mustang302
Vacuum secondaries are nice for street cars. Mech 2nds work, but you have to know what you're doing. 650cfm is prolly all that engine really needs, but regardless, it has to be tuned correctly.
lovesilver
Members Mustangs
May 9, 2019 09:18 PM
Explosive
Oct 2, 2015 07:45 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
RCS02v6
Sep 29, 2015 01:46 PM
