Starter not dis-engaging
Old Jun 10, 2008 | 12:26 PM
jmcmustang's Avatar
jmcmustang
Default Starter not dis-engaging
I have a 68 289 that I replaced the starter on. Old starter was not turning motor hard enough (I think I killed it when trying to install dizy). The starter certainly is turning motor hard enought nowto start, but occasionly spins like it does not dis-engage. I tried reinstalling, (top bolt first then bottom), giggling and loosening bolts a bit. The bolt loosening worked best, but seems lame. Any ideas? BTW-This is the first car I have worked on, so I have been relying on friends to help. Thanks!!!
Old Jun 10, 2008 | 02:17 PM
92stangerang's Avatar
92stangerang
Default RE: Starter not dis-engaging
they make starter shims for gm cars so i would imagine they makem for fords too. its either starter shims or your starter already went bad. i toasted a reman starter in 45 mins before. and no i wasn't trying to start it the entire45 minutes. lol
Old Jun 10, 2008 | 08:46 PM
MustangMan628's Avatar
MustangMan628
I have also returned autozone starters in the same day before because they are $hit. I have returned non Motorcraft Solenoids too within a week because they are just built so cheap and every now and then you get one that was just destined to fail from the factory, unless it actually came from a Ford dealership. You definitely know when your starter stays engaged. It's an unmistakable sound. I would check starter and solenoid first. I had to bench test an autozone starter like a dozen times in a row before it failed. I did it right in the store in front of the employees because I got so fed up with my starter dying or staying engaged every other day of the week, and I just wanted my money back for a week old starter that was crap.
Old Jun 11, 2008 | 10:38 AM
Gary H's Avatar
Gary H
I would bet on the solenoid being the problem.
Old Jun 11, 2008 | 11:23 AM
jmcmustang's Avatar
jmcmustang
Thanks for info.. I went down to auto store and they only had GM shims. They suggest I pull and bring in to test if engaging properly. Probably do that. I had also just replaced the solenoid.
Thanks for feedback.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
logan409
Sep 26, 2015 07:43 PM
jaiidutch
Sep 14, 2015 10:29 AM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
daytooday
Sep 1, 2015 09:33 AM
