clutch cable
Old Jun 12, 2008 | 01:23 PM
TRL12087's Avatar
TRL12087
Default clutch cable
i replaced my stock cable and quadrant with steeda parts along with a firewall adjuster about 2 years ago and the cable snapped on me the other day. the original lasted about 20 years compared to 2 on the steeda cable. so do i go with another steeda cable or just a stocker from the auto parts store?
Old Jun 12, 2008 | 01:41 PM
945LSTANG's Avatar
945LSTANG
Default RE: clutch cable
my steeda cable did the same thing after 9 months. i replaced it with a stock cable and its been all good.
btw..the stocker needs to be modified a little to work with the firewall adjuster.
Old Jun 12, 2008 | 09:52 PM
Jfsram's Avatar
Jfsram
Do you have some killer base pressure on your clutch?
Where did it break.
If it's under the dash....
Check the cable to quadrant alignment.
Where it pokes out of the firewall. It needs to run straight to the quadrant and not on an angle.
Old Jun 13, 2008 | 11:26 AM
TRL12087's Avatar
TRL12087
it broke right at the bend on the quadrant. i think it must have been stretching pretty bad because i had to adjust my firewall adjuster every 2 weeks. so it probably was under a good amount of pressure, but the car wouldnt go into gear unless i adjusted it that way.
Old Jun 13, 2008 | 07:16 PM
SnakeCarDriver's Avatar
SnakeCarDriver
ORIGINAL: 945LSTANG
how long since the replacement ?
Thunderball
15
Nov 22, 2015 11:49 PM
kevsgt
Oct 9, 2015 10:12 PM
breaking
Oct 2, 2015 01:27 PM
Explosive
Oct 2, 2015 07:45 AM
junior04
Sep 28, 2015 10:53 AM
