Tune issues
Old Jun 13, 2008 | 06:09 PM
mikehands's Avatar
mikehands
Default Tune issues
2006 GT 4.6, cold air, cat-back exhaust
Am running a 93 tune from VMP Tuning. Problem is around 2000 rpm I have a serious lag. Until it runs up to about 3000 rpm, it feels like a dead pedal. What is the recommended spark retards for these tunes? Also, what is Global Spark?
Old Jun 14, 2008 | 05:48 PM
USMC1775's Avatar
USMC1775
Default RE: Tune issues
As far as I understand, when you purchase tunes from shops, they are supposed to require no additional modification on your part in order to make the tune function properly. I would call up that shop you get the tune from
Old Jun 15, 2008 | 06:03 AM
02TorchRedGT's Avatar
02TorchRedGT
You just have to experiment with it...all cars wont run the same with the can tunes. If your using a SCT tuner then you can adjust your timing for different rpm ranges. If your car runs good in 0-2k rpm range then i would try to adjust the 2-4k rpm range. When i got my 93 tune from brenspeed the timing was too far advanced for my motor...causing "pinging" under a load. I had to retard my 0-2k range 6 degrees and other rpm ranges about 4 degrees.
articman
Jun 21, 2018 11:45 PM
Sep 8, 2015 06:25 PM
zanemoseley
Sep 6, 2015 12:58 PM
Emblazoned
Sep 3, 2015 10:45 PM
whatsup62
Sep 3, 2015 01:38 PM
