driveshaft rub
Old Jun 16, 2008 | 09:53 PM
IownaMustangNow's Avatar
IownaMustangNow
Default driveshaft rub
just got lowering springs installed and my driveshaft rubs!! only when i go over bumps or give her the power from a dig. . is this normal? by the way its a 1.5 inch drop all the way around (eibach springs)
Old Jun 16, 2008 | 10:36 PM
92stangerang's Avatar
92stangerang
Default RE: driveshaft rub
if the kit came new it should have come with a replacement bushing stop. if not justcut the old one in half.... its located in the tunnel closer to the tranny.... if thats the part thats rubbing.
Old Jun 17, 2008 | 12:01 PM
945LSTANG's Avatar
945LSTANG
ORIGINAL: 92stangerang
the eibach kits come with a new bump stop. did you install it?
i installed mine and have had zero rubbing problems.
Old Jun 18, 2008 | 11:23 PM
pcs's Avatar
pcs
i guess you can be more specific on what is actually rubbing, if you know. b/c when i lower mine with bbk springs i had some slight rubbing too, but it was from the flow masters touching the driveshaft.
Old Jun 19, 2008 | 06:48 PM
02TorchRedGT's Avatar
02TorchRedGT
ORIGINAL: khooper
If the rubbing is minor you can live with it, or even cut the tyre slightly to make it fit- bodgy, yes, but as long as it's only a slight cut- well short of the belts- it is okay. Anyone thinking this is totally stupid should bear in mind tyres are DESIGNED to wear out and become thinner.
Rubbing is not good on any part. I think cutting a tire is nuts myself....of course they wear thinner...but a little more evenly than cutting layers off. Unless your darn good with a cutting tool...your tire will never be balanced correctly.
Old Jun 20, 2008 | 04:39 PM
945LSTANG's Avatar
945LSTANG
ORIGINAL: khooper
_____________________________
CHECK OUT: AUTOPARTSWAREHOUSE.COM
that idea sounds retarded to me.
btw...i woundnt take advice on tires from someone who doesnt even know how to spell tire.
Old Jun 21, 2008 | 08:15 AM
IownaMustangNow
i did install the new bump stop so im not sure if thats what is rubbing .. any other ideas?>
Old Jun 21, 2008 | 12:51 PM
USMC1775's Avatar
USMC1775
Mine was being notched by I think the e-brake bracket, I just bent it a little
mtgldr
Feb 3, 2024 09:00 PM
baddog671
Jul 26, 2016 01:20 PM
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
ccdguy
Sep 19, 2015 05:20 PM
