rear tires lock up?
Old Jun 29, 2008 | 09:02 PM
n1netyn1ne's Avatar
n1netyn1ne
Default rear tires lock up?
Ok something weird happened today... almost caused a horrible accident..
I was driving about 34 mph in 3rd gear andI started to hear a howeling sound? Coming from the rear or backseat area?... SeemswhenI stepped on the gas the engine responded but the trans or something in thedrive tran didnt keep up and must have locked up my reartires or something...as they screeched on the road..and swung the rear end out... (by this time i had it out of gear and back in neutral..and was able to pull right into an empty parking spot.) luckily there was noone behind me or next to me...or I would have totaled this thing instantly...
weird thing is i checked everything out after it happened and all gears still work.. but the rear end is still making a humming sound in gear...
Clutch is 4 months old...
.. I think the differential is toasted..or my transmission is going out the window...
...I noticed there is a nice black oil spot where i park it ... its right below the where the rear differential would sit....
..My guess is that when i took it out...it was probably empty/really low diff. gear fluid? or worn driveshaft supports?.. tranmission mount??
Ughhh... any incite..anyone?? damn machanic is closed this whole week for the 4th...
Old Jun 29, 2008 | 10:47 PM
92stangerang's Avatar
92stangerang
Default RE: rear tires lock up?
sounds like rearend to me. it probably chipped a tooth on one of the gears then making the tires lock up. is it drivable now? i would just take the diff cover off and take a look. wear some gloves and have a catch pan ready.
Old Jun 29, 2008 | 10:50 PM
Jfsram's Avatar
Jfsram
ORIGINAL: n1netyn1ne
This makes me think your problem is the transmission.
I don't suppose you accidentally engaged 1st gear?
Old Jun 29, 2008 | 11:15 PM
n1netyn1ne's Avatar
n1netyn1ne
I'm pretty sure... it was in 3rd andIwasnt pressing on the accelerator... so it was slowing down the car... thenI get back on the gas alittle bit and thats when it all happened... the engine responded but drive tran didnt seem to as normal..
Its bearly drivable ....rear end is noisy... and i dont think i want to risk this happening again...
Old Jul 1, 2008 | 06:40 AM
88stangaruu's Avatar
88stangaruu
yea, sounds like a diff to me. You said it had an oil spot where the rear end sits. Sounds like it finally went dry and locked up on you.
Old Jul 2, 2008 | 05:48 PM
Blckstng93's Avatar
Blckstng93
Sounds like a diff to me to.
Old Jul 2, 2008 | 05:57 PM
khooper's Avatar
khooper
if it is really a rear tire lock up problem then you must check and try bleeding the brakes all the way around the car. Check to make sure that the brake is not dragging.
________________________
Check out: Autopartswarehouse.com
musnicki
Sep 23, 2015 07:11 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
2007CalSpec
Sep 9, 2015 05:37 PM
M3hunter
Sep 5, 2015 03:42 PM
