wheel size
Old Jul 2, 2008 | 08:36 AM
MMERRIMAN's Avatar
MMERRIMAN
Default wheel size
it is a 91 mustang 5.0 complete edelbrock performer rpm set up bbk throttle body crane gold roller rockers, bigger injectors keith black pistons,frame is tied, just dont have wheels on it yet... the question is what can i fit on the rear i.e. rim width and backspacing. what is the 4 lug bolt pattern i wuld like to go with 15" rims in the back just dont know what else i need
Old Jul 2, 2008 | 01:21 PM
aru_next's Avatar
aru_next
Default RE: wheel size
I see alot of people going with a 15 by 8 inch with 5.5 backspace, I guess you could run a 15 by 10, thats what I want. But you might need to trim depending on the tire.
Old Jul 2, 2008 | 01:35 PM
Mikes5.0's Avatar
Mikes5.0
I just went through the same thing.your 4 bolt is a 4.25. As far as your wheel size I went with eights over tens just because the the biggest tire you can fit comfortably is a 275 and even with that you will need to beat the hell out of your inner fender to stop it from rubbing.As I was ordering tires I noticed that they didnt suggest using 275 tires on anything bigger than a 9.5 wheel. Its probably a pain in the *** to get the bead set.Good luck!
Old Jul 2, 2008 | 03:36 PM
aru_next's Avatar
aru_next
ORIGINAL: Mikes5.0
I had 275's on mine with the quads and didnt beat anything they fit fine, it was tight but they didnt rub.
Old Jul 2, 2008 | 10:51 PM
ExtrmZ's Avatar
ExtrmZ
saw one today, it had 4-lug cobra r's with 275/45/17's on them..
Old Jul 15, 2008 | 02:13 AM
sransari's Avatar
sransari
just look on tirerack.com...put in your car and search for wheels
Tivo304
Aug 28, 2023 12:19 PM
Nov 10, 2015 11:39 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
Sep 8, 2015 06:25 PM
Sep 3, 2015 07:14 PM
