help with mods
Old May 8, 2005 | 07:57 PM
98 white stallion's Avatar
98 white stallion
Default help with mods
i have flowmaster exhaust and cold air intake, what kind of pulleys should i put in to get the most horsepower out of, and about how much would it cost?
Old May 8, 2005 | 08:45 PM
Dan04COBRA's Avatar
Dan04COBRA
Default RE: help with mods
$200 bucks will get you a great set of UDP's. Steeda UDP's are good, also you can order March UDP's, make sure you refer to my thread in the 4.6 section and get the correct part numbers so you don't end up with a piggy back setup like I did.
Make sure you get pulleys that come with a crank/puller dampner as one solid piece. Piggyback UDP's weigh alittle more and do not allow you to use a timing adjuster.
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
UrS4
Oct 3, 2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
TimeLord101
Oct 1, 2015 06:40 AM
