Throttle Body
Old Jul 23, 2008 | 08:44 AM
sonnyman30's Avatar
sonnyman30
Default Throttle Body
Question for someone with knowledge. I have a 2005 mustang gt. At idle the engine stalls or anytime I press the clutch when changing gears if I let the rpms dropp to about 1 it stalls. Autozone did a diganostic check and it read not getting enough air or air temp. They suggedted I change the a sir flow snesor. Took it to ford and they said that the throtlle control valve was bad and i need to have the throttle body replaced. Is the valve and the throttle body incorparated into one piece becasue they are talking about a 500 dollar bill. Can anyone give me some advice on this?
Old Jul 23, 2008 | 11:32 AM
ohfiveride's Avatar
ohfiveride
Default RE: Throttle Body
i just had the same problem.....i am currently waiting by the door for the ups man to drop off a new throttle position sensor....my car finnally threw codes...7 of em and thats the problem...get a digital voltmeter and read the yellow wire on the tps while the car is on but not running..should be about .98 volts at idle...not too much higher...then read the voltmeter as you step on the gas pedal slowly until wot...it should read a smooth continuous level until about 4.8 volts....if it skips at a certain point and gets a crazy reading then you need to replace your tps...if your level at idle and wot dont look like these then you also need to replace it...
Old Jul 23, 2008 | 12:22 PM
sonnyman30's Avatar
sonnyman30
So is there any reason why you think it could be the throttle body itself because Im getting ready to have to pay 530 for this at the ford dealer
Old Jul 23, 2008 | 08:10 PM
51derrill's Avatar
51derrill
Soneyman:
You can get a great after market Throttle Body (Brand New, Steeda I Think) for $268.00. There is nothing to installation. No way I would pay Ford their over the top labor prices!
http://cgi.ebay.com/ebaymotors/Parts...3756.m14.l1318
Old Jul 23, 2008 | 10:13 PM
kushal_22's Avatar
kushal_22
I just Bought the BBK T/BPlenum Combo for 250 So far it satisfies....just fine
Malcom
Old Jul 23, 2008 | 10:40 PM
Solitear's Avatar
Solitear
Buy an aftermarket one WOW 500 bucks the 62mm bbk off brenspeed is 268 i think someone can correct me if i am wrong....
Old Jul 23, 2008 | 10:55 PM
ohfiveride's Avatar
ohfiveride
i just got my throttle position sensor from newfordparts.com ...the lady that took the order knew exactly what part i was talking about....the throttle body and tps are not one peice..they are jerking you....the tps cost me 65.....i will install it tom and let you guys know how it turned out.....it came in a box with great instructions on installation and 2 new torx screws....
Old Jul 24, 2008 | 06:23 PM
kushal_22's Avatar
kushal_22
ORIGINAL: ohfiveride
I did not say "TPS" I said "Plenum"
Looks like you got things all sorted out though...which is what you want.
Malcom
UrS4
Oct 3, 2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
guitarman376
Sep 30, 2015 05:54 PM
GLOCKer
Sep 28, 2015 07:36 AM
2poor4u2
Sep 26, 2015 11:08 AM
