Need help.
Old May 8, 2005 | 09:57 PM
RebelRoan's Avatar
RebelRoan
Default Need help.
I recently bought an 82 stang with an L6, the L6 is going out, and its worth it to replace or rebuild it. What I want to know is whether I can fit a 302 in its place? Any help would be greatly appreciated.
Old May 8, 2005 | 10:21 PM
GreyStang's Avatar
GreyStang
Default RE: Need help.
Well the 302 was an option for your car back in '82, so swapping one in now should be no problem. And if you do the wreaking yard route you can get all the linkages & brackets you need for the swap, should be fun! A couple things..
-you're probably better off using a carburated 302 not a fuelie,, the install would be easier unless you WANT to tackle installing the computer & high pressure fuel system the injected engine would need
-what tranny are you gonna use? Auto or 4-speed?
Old May 8, 2005 | 10:24 PM
RebelRoan's Avatar
RebelRoan
cool, i would definitely go with the carbed, and as for the tranny, problably the 4 speed, depending on cost.
Old May 9, 2005 | 12:32 AM
C/Note's Avatar
C/Note
I ♥ Acer
you will need a k member out of a 4 cyl or v-8 car l-6 member wont work...
Thunderball
15
Nov 22, 2015 11:49 PM
Dathan
Oct 5, 2015 05:52 AM
NYstang
Sep 30, 2015 09:56 PM
mustangheaven
Sep 29, 2015 11:00 AM
