Mach 1000 Amps
Old Jul 26, 2008 | 05:46 PM
88Eagle's Avatar
88Eagle
Default Mach 1000 Amps
Hey there. I bought an 04 Mustang GT with the Mach 1000 Audio system last Saturday. I am thinking about trying to move the amp tray higher in the trunk so that I can fit some things in the trunk, like my guitars, since they don't currently fit. I noticed that there is a total of 6 amps, 2 mounted under the rear speakers, and 4 on the tray. Is there going to be any problem with the amps if I do that, granted, the wiring harness may not reach, but is there going to be any other problems that may occur? Any help would be great.
Old Jul 26, 2008 | 09:47 PM
ewgoetz's Avatar
ewgoetz
Default RE: Mach 1000 Amps
Shouldn't be as long as it isnt to much of a hack job. If you relocate them and you extend the wires make sure you soder them and put shrink wrap over the area where u sodered otherwise there shouldnt be to much of a issue. Also When you relocate them make sure you don't drill into anything important (Like drilling into the bottom floor and going into the fuel tank, fuel line or another wiring harness). Same goes for drilling into the sides. Also make sure after it's done it is solid.
Old Jul 26, 2008 | 10:33 PM
88Eagle's Avatar
88Eagle
I am hoping to modify the tray that holds the amps, and use the same bolts that currently anchor it to the trunk.
1BAD3V
Tennessee Regional Chapter
Oct 6, 2016 12:12 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
1BAD3V
Indiana Regional Section
Sep 26, 2015 09:03 AM
