c4 transmission crossmember help
Old Jul 28, 2008 | 12:45 AM
351mustang's Avatar
351mustang
Default c4 transmission crossmember help
ok..i got a 351w and c4 tranny..i swapped in to replace the 4cyl..motor and tranny are dropped in a bolted up..and i put the stock 4cyl crossmember back in and it does bolt up to the c4 ( i expected this)....so i was wondering does anyone know of a crossmember that would work for this swap/setup? the bolts on the c4 the appear that would go into holes on a crossmeber are to far forward..so i guess i need the crossmmeber to be able to slide forward towards the engine more to reach the bolts on the tranny?
can anyone help me out?
and also i need a crossmember that would allow an X pipe to run underneath...thanks
Old Jul 28, 2008 | 06:09 AM
ewgoetz's Avatar
ewgoetz
Default RE: c4 transmission crossmember help
YOu try a GT or cobra crossover? go to a junk yard and try it out. I know 4 cyl engine mounts and I think the cross members are differnet not sure how but the GT also had dual exhaust so they should at least clear ur exhaust system.
Old Jul 28, 2008 | 07:42 AM
92stangerang's Avatar
92stangerang
get on ebay and type mustang crossmember. thats where i got mine. youll also need differnt bellhousing bolts other than the a4ld. the a4ld bolts are too long.
Old Jul 28, 2008 | 01:00 PM
351mustang's Avatar
351mustang
thanks guys..im goin to check out the gt crossmembers..but i know most GTs dont come with c4 tranys? or maybe they do
and as for the bellhousing bolts i already figured that one out thanks tho
and the one u got on ebay did u use it for a c4 tranny?
Old Jul 28, 2008 | 02:45 PM
92stangerang
yeah. it says it was modified for a c4though. it looked just like this one.http://cgi.ebay.com/ebaymotors/1987-...spagenameZWDVW .
I think some of the crossmembers you might have to cut one side each bushing and do some welding. but the link i just posted^^ is identical to mine.
Old Jul 28, 2008 | 02:47 PM
92stangerang
vs. this one you need to do some cutting .... see how the back side is inch or so.. the prior link is flush.... http://cgi.ebay.com/ebaymotors/1980-...spagenameZWDVW
4cylinderplus2
Oct 9, 2020 07:45 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
wraith777
Sep 28, 2015 10:49 AM
