check engine light code
Old Jul 30, 2008 | 01:41 PM
horak24's Avatar
horak24
Default check engine light code
I have an 06 saleen and the check engine came on so I checked the code with my scanner and it rea P0171 anyone out have the ability to tell me what this is? ( I am assuming an 02 sensor or something small)
thanks
Old Jul 30, 2008 | 01:52 PM
Solitear's Avatar
Solitear
Default RE: check engine light code
A P0171 lean code for bank 1 is the cylinder bank on the RIGHT (passenger) side of the engine on Ford vehicles with a V6 or V8 engine and rear-wheel drive
Thats what i think could be wrong.
Trouble shooting: One of the most common causes of Ford P0171 and P0174 lean codes is a dirty mass airflow (MAF) sensor. The MAF sensor is located in the air inlet tube
just ahead of the throttle body.
VACUUM LEAKS
Another common cause of Ford P0171 and P0174 ean codes is an engine vacuum leak. Ford TSB 04-17-4 details procedures for checking fuel trim and looking for vacuum leaks.
can be another cause
djbigskrilla
Sep 20, 2022 01:04 AM
labudski
Aug 24, 2015 07:23 AM
microgt
Aug 20, 2015 07:12 AM
mweiland
Aug 13, 2015 05:11 PM
drumhedd2005
Aug 13, 2015 09:59 AM
