what tools can i use
Old Aug 1, 2008 | 02:10 AM
mycar's Avatar
mycar
Default what tools can i use
i was pullin off the water pump but when i was doin that i snapped 3 of the bolts of in the block what tools r there to help me pull the bolts out
Old Aug 1, 2008 | 06:33 AM
ewgoetz's Avatar
ewgoetz
Default RE: what tools can i use
Is therea stud left or is it clean off the block? If it's clean off the block you can get a screw extractor from lowes, homedepot, or any other hardware or automotive store. You driss a smaller hole diamiter than the screw that they provide to you with the kit than use the tool to unscrew it. If its still sticking out a good ditance than grind a small flat spot and use a good set of quality visegrips. Also before you do either of those make sure you soak the bolts with PB blaster for at least 15 to 30 min before you try to remove them.
Old Aug 1, 2008 | 04:39 PM
Solitear's Avatar
Solitear
+1
Yea poster aboves idea is the best way to fix em well pull em
Old Aug 1, 2008 | 08:01 PM
ewgoetz's Avatar
ewgoetz
Thats basicaly what I did years ago to my Bros bronco cause hte water pumped blew on it. that was about 15 years ago.....what sucked was we had to go all over creation to get the one that snaped off. I feel your pain. That is why I said to use lots of PB. If it don't budge spray some more and come back in anotehr 15 min.
Old Aug 3, 2008 | 06:08 PM
PONY GUY's Avatar
PONY GUY
I am in the same boat I found a broken bolt that a previous owner jsut put back in with a bunch or silicone on a buddied car . It the bolt on the D/s that is in between the 2 for the ac braket . It was snapped off with only 3 treads left on the bolt I didnt take the timeing cover off yet but with how much thread was left on the broken bolt . Would you say there is good chance it might have some left stickin out that I could put a pair of vise grips on. Or does the bolt use all the thread on it to tighten it and looks like I might have to drill and tap it .
Sorry to hijack the thread u started Its been a headach all weekend with me with this same problem
Old Aug 4, 2008 | 09:46 AM
ewgoetz's Avatar
ewgoetz
Hey Pony, I would use a screw extractor kit on it. If you grind up whats left It will be hard to get the drill bit centered from the screw extractor kit.
Old Aug 4, 2008 | 04:28 PM
PONY GUY's Avatar
PONY GUY
yeah but what I was wondering is how much bolt would be sticking outa the block if the bolt snapped off at the third threadgoing away from the shoulder or "unthreaded" part of the bolt ??? Dose the bolt have a decent amount of thread left sticking out past the block after its tight or is the shoulder of the bolt the only thing that sticks out when the bolt it tight on the pump
mtgldr
Feb 3, 2024 09:00 PM
Urambo Tauro
Jun 10, 2016 03:28 AM
jrrhd73must
Oct 2, 2015 09:17 PM
TfcCDR
Sep 14, 2015 12:08 PM
Jb145700
Sep 11, 2015 12:28 PM
