Clutch cable adjustment
Old Aug 5, 2008 | 04:33 PM
Bly's Avatar
Bly
Default Clutch cable adjustment
I have an 83 Mustang t-5 Tranny. I put in a new clutch, now clutch engagment is at the end of clutch release. How do I adjust this? Do I adjust at firewallor at clutch pedal? It is all stock, no aftermarket adjusters.
Thanks,,,Brandon......
Old Aug 9, 2008 | 12:01 PM
awtoo's Avatar
awtoo
Default RE: Clutch cable adjustment
Hey. If you haven't fixed it by now, here's my 2 cents. I had a similar problem with my 87 Mustang. Someone had replaced some components in the clutch assembly and just made a huge mess of things. With the pedal all the way to the floor I couldn't get a gear...and when I did the clutch would slip horribly. There is an adjustment in the firewall and the cable I had also had a bolt at the end where it connected to the transmission. There is no way to adjust it in the clutch assembly. I would try at the transmission first then fine tune the adjustment at the firewall. In my case that didn't even work. I had to have the actual pedal cut and rewelded at a more acute angle to give it more travel. Now it works great. Hope that's some help....
Thunderball
15
Nov 22, 2015 11:49 PM
kevsgt
Oct 9, 2015 10:12 PM
breaking
Oct 2, 2015 01:27 PM
winner99
Sep 30, 2015 07:04 PM
junior04
Sep 28, 2015 10:53 AM
