car pulls to the left
Old Aug 6, 2008 | 03:47 AM
boss281's Avatar
boss281
Default car pulls to the left
ive had this problem for a while now, everytime i get on the gas my car will pull to the left and when i let off it will stop pulling . this is more noticeable the faster im going and at med-high rpms..... ive had my diff checked they found no problems also checked the torque boxes and the seem ok. i have aftermarket u/L control arms non adj. street tires and a couple bolt ons. i dont know what it could be???? help!! [&:]
Old Aug 6, 2008 | 07:42 AM
ewgoetz's Avatar
ewgoetz
Default RE: car pulls to the left
Did you check the front suspension? if thats ok than next I'd look for a sticking brake caliper can be either in the front or back....
Old Aug 6, 2008 | 08:02 AM
Chopper's Avatar
Chopper
Yeah,check the front suspension.I'd start by taking the car to a first class alignment shop with the latest equipment and top notch operators.
The control arms could have worn out bushings.
Does it do anything when you use the brakes?
How about hard braking?
Pulling to one side with no brake problems,(worn pads,sticking rotors,collapsed hoses,etc)tends to bein the control arm bushings or an alignment discrepancy.
Old Aug 6, 2008 | 12:11 PM
boss281's Avatar
boss281
brakes are ok a little worn if anything lol. when im not accelerating in goes straight thats why i dont think the front susp has anyhing to do with it. but i may need new bushings........ ill look into that thanks for you help guys.
Old Aug 8, 2008 | 11:09 PM
Jfsram's Avatar
Jfsram
I highly doubt this has anything to do with the brakes. Brakes do not know when when you are accelerating.
Study the rear suspension closely. With an automatic you can torque it up in drive against the front brakes while on a drive on hoist. Note the wheelbase or rear axle for movement.
With a stick. Anyone with driver mod can simulate the above.
Old Aug 10, 2008 | 01:56 PM
1992foxstang's Avatar
1992foxstang
yeah i'd say this something in the rear end of the car check your upper control arm bushings. my car did that once because of a broken shock but i doubt that is your problem
djbigskrilla
Sep 20, 2022 01:04 AM
chain
Aug 17, 2015 08:52 AM
cvarner131
Aug 17, 2015 07:38 AM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
