90 gt headlight problem
Old Apr 6, 2003 | 03:03 PM
insp28's Avatar
insp28
Default 90 gt headlight problem
I have a small problem with a 90 GT headlights not working. Just replaced switch that controls headlights and fog lights. Still not working... When you pull back on directional lever high beams work but indicator light does not. Any suggestions????
Old Apr 6, 2003 | 03:13 PM
noslow50's Avatar
noslow50
I ♥ Acer
maybe it's just a burnt out indicator light in the dash....
Old Apr 7, 2003 | 06:14 PM
91GT5.0's Avatar
91GT5.0
Not to hijack this thread, but it's sort of on topic. I am replacing the headlights on my car. I can't figure out how to get the studs into the back of the headlight. They do into the plastic things on the back, then throught the headlight panel, and then you use nuts to tighten and adjust to the headlight panel. I can't get them to sit flush/go all the way in. Do I need to buy new clips? Sorry if that is vague, I know it's hard to figure out without pics, I'll try to get some tonight and post a diff thread.
And to give you maybe some ideas to try, insp28, maybe it's the fuse. I don't know if headlights and highbeams run off the same fuse, but it's something you can check.
Old Apr 8, 2003 | 01:07 AM
Sicy Stang's Avatar
Sicy Stang
I just replaced my brake light switch. What a friggin pain in the *** that was.
Old Apr 9, 2003 | 12:21 AM
noslow50's Avatar
noslow50
I ♥ Acer
sorry i don't know anything on how to play with head lights on a fox....
Nurdyguy
Jan 20, 2025 04:38 PM
StalkerGT
Nov 28, 2015 03:09 PM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
Mobiusone stang
Sep 7, 2015 08:46 PM
amandahchase
Sep 3, 2015 10:09 AM
