press out pinion
Old May 12, 2005 | 07:45 PM
mkspeed26's Avatar
mkspeed26
Default press out pinion
well, i just got back from wackin my pinion gear for about a half hour with a sledgehammer, and it wont budge. would takin it to a machine shop and havin them press it out be the next best way to do it?
Old May 12, 2005 | 08:48 PM
IWinULose's Avatar
IWinULose
Default RE: press out pinion
ORIGINAL: mkspeed26
That is the only way. You'll have it done right and won't have to worry about busting something up. Besides, you'll have to press the new one on too. Keep us posted.
Old May 12, 2005 | 10:19 PM
C/Note's Avatar
C/Note
I ♥ Acer
you cant get the bearing off ,,this is what i do heat it up slight with a propane torch it will slide right off then put it on your other one with the same shim behind it ,,on your new pinon you need to dress up the small end where the bearing ride at if not you will be pushing your new seal though ..you know what im saying ...???i dont know if you can see where its been dressed at ..
[IMG]local://upfiles/10419/100A2D49A9BA4C6CB145AEB3471C0EE0.jpg[/IMG]
Old May 12, 2005 | 11:12 PM
mkspeed26's Avatar
mkspeed26
just a clearafication, it is stuck in the housing. the pinion is bent (thats why im replacing it) and i think that has somethin to do with it
Old May 13, 2005 | 08:56 PM
mkspeed26's Avatar
mkspeed26
well, i went out to the machine shop today and im pissed [:@]. the machinist looked at hit, and said "wow that sucks". apparently the bearing welded itself (from extreme heat) to both the pinion gear and the bearing race. ya, so i need to get a new rearend [:@].
Old May 13, 2005 | 09:18 PM
C/Note's Avatar
C/Note
I ♥ Acer
i would try and cut the caged bearing retianer ,,than see if it comes out ...dam never had that prob..he must have run no lube than added some to throw you off,,,you couldnt move it when you got it right..?
mtgldr
Feb 3, 2024 09:00 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
baddog671
Jul 26, 2016 01:20 PM
Thunderball
15
Nov 22, 2015 11:49 PM
KingRando
Oct 2, 2015 08:06 AM
