bad starter?
Old Aug 15, 2008 | 04:08 PM
spdsmoky's Avatar
spdsmoky
Default bad starter?
Help I have an 1984 mustang with a 302. When I turn the key to start the car everthing goes dead. The car does not turn over just a click and all dead. If I disconnect and re-connect the battery I have power again (dome light and gauges work). What would cause this
Thanks ray
Old Aug 15, 2008 | 05:22 PM
92stangerang's Avatar
92stangerang
sounds like a bad connection. clean your posts and check the wiring from your battery and starter. (could be corroded). make sure your battery has enough voltage also.
Old Aug 15, 2008 | 06:12 PM
GeorgeGoble's Avatar
GeorgeGoble
Yeah, get you a wire brush and clean all the electrical connections from the battery to the starter. The ground is just not grounding.
Dathan
Oct 5, 2015 05:52 AM
KingRando
Oct 2, 2015 08:06 AM
ChampInSD
Oct 2, 2015 04:55 AM
UrS4
Sep 30, 2015 10:13 AM
logan409
Sep 26, 2015 07:43 PM
