Wheel Size Increase
Old Aug 14, 2008 | 09:42 PM
Brizice's Avatar
Brizice
Default Wheel Size Increase
I am going from 245/45/17 wheel to a 245/40/ 18 on a 99 cobra. Any issues to consider before doing this?
Thanks
Old Aug 14, 2008 | 09:49 PM
ryan1994mustang's Avatar
ryan1994mustang
im assuming this is with a new set of rims, but other than that you should be just fine.
Old Aug 15, 2008 | 06:19 AM
OnyxCobra's Avatar
OnyxCobra
go wider, why so narrow?
Old Aug 15, 2008 | 08:30 AM
Brizice's Avatar
Brizice
Yes, new set of rims. Any suggestion on width for daily driver?
Old Aug 15, 2008 | 07:08 PM
945LSTANG's Avatar
945LSTANG
what is the width of the rims that you are using?
Old Aug 15, 2008 | 07:12 PM
ExtrmZ's Avatar
ExtrmZ
i would go 8" to 9" if your car can fit them in, i am not sure about the size of your wheel wells on your 99, but i can get 9" in my fox with no problems.. so you should be able to do the same
Old Aug 16, 2008 | 12:22 PM
OnyxCobra's Avatar
OnyxCobra
If you want something you can rotate no problem I'd suggest 18x9s with 275/35-18 all around, you may rub a little at full turn in the front though unless you upgrade to 03 Cobra control arms.
Old Aug 16, 2008 | 12:56 PM
Brizice's Avatar
Brizice
Thanks for the help.
Tivo304
Aug 28, 2023 12:19 PM
Nov 10, 2015 11:39 AM
Oct 5, 2015 06:07 PM
Sep 8, 2015 06:25 PM
Sep 3, 2015 07:14 PM
