Pinstriping tape removal
Old Aug 16, 2008 | 05:20 PM
derrill51's Avatar
derrill51
Smile Pinstriping tape removal
I have had pin striping tape applied for about two months. The longer I look at it, the more I realize that I should have used another color. What is the most effecient way of removing this tape? I am thinking about a hair dryer ir a heat gun. If that works, what is the best way to remove the glue residue. I was thinking Acetone or Alcoho? Your help is much appreciated.
Best/ Billl
Old Aug 16, 2008 | 05:56 PM
ryan1994mustang's Avatar
ryan1994mustang
yeah, just use a heat gun to warm up the adhesive and peel it off. goo gone or something like that will take the sticky residue right off.
Old Aug 16, 2008 | 06:19 PM
ExtrmZ's Avatar
ExtrmZ
yeah goo gone works well, there are also products out there that are adhesive removers, i used some one time, it worked about the same, i would recommend goo gone
Old Aug 17, 2008 | 01:34 PM
Blckstng93's Avatar
Blckstng93
Goo Gone
WD40
Peanut butter (yes, peanut butter)
Make sure to wash the 'stang afterwards then wax it if you arent adding new stripes right away.
Old Aug 18, 2008 | 04:45 PM
derrill51's Avatar
derrill51
Thanks much guys. The heat gun worked perfectly. Heating the tape in two to three foot sections, it peeled right off. This method leaves almost no residue. However, I used "OOPS!" unstead of "GOO GONE", to remove the little adheaive that was left. the results were excellent.
Thanks Again/ Bill
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
TimeLord101
Oct 1, 2015 06:40 AM
