Power Window Problems Still.
Old Aug 28, 2008 | 12:46 AM
drew50's Avatar
drew50
Default Power Window Problems Still.
Well I was having problems with my driver side window going up and down. It would move a little then stop. So I changed the bushings in the window lift motor and then the whole motor stopped working. Im not sure if I broke it though I dont think I did. So I just bought a brand new lift motor and put it in and it worked great. Now two days later the window wont roll down at all. I took the lift motor out and watched it while hooked to the switch. It would roll up perfectly but would barely move when pressing down. So I went and got a different motor and it did the same dang thing. Now Im wondering if the problem is something else. The switch or the relay or maybe the one touch relay. I really dont know what to do and need help really bad this is freaking frustrating. Can someone help me out im not even sure where the relays are. Thanks
Old Aug 28, 2008 | 12:42 PM
drew50's Avatar
drew50
Anyone had this happen to them?
Old Aug 28, 2008 | 12:55 PM
ewgoetz's Avatar
ewgoetz
I'd say its the switch.
Old Aug 28, 2008 | 06:51 PM
drew50's Avatar
drew50
Ok I checked all the fuses and the window relays those are good. Now when I press the button the window will move down just a little bit. You can keep getting it to move by keep pressing the button. When I press it I can hear the one touch down black box thing click. Does anyone know what to do. Or what the problem is
Old Aug 29, 2008 | 12:13 PM
drew50's Avatar
drew50
Is it possible that the motor can move perfectly one way but not the other. If so then maybe I need to try another motor. If not then it has to be something in the wiring. Does anybody know?
Old Aug 29, 2008 | 12:58 PM
quiksilvrstang's Avatar
quiksilvrstang
I would try a different switch. I've had them do it both ways, not go up once down or not go down when up and both times it has been a bad switch
Old Aug 29, 2008 | 06:53 PM
drew50's Avatar
drew50
Ok I have tried switching the wires around and also used a switch off my friends convertible. It still does the same thing. I have pretty much narrowed it down. I think it is the one touch down mechanism in the door panel, the motor again, or possibly a circuit breaker. Does anyone know if there is a circuit breaker for just the driver window. And has anyone ever had the one touch down mechanism do this to them?
drfister
May 3, 2018 10:38 PM
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
movielover40
Aug 27, 2015 10:13 PM
