HELP!! Battery dead cant get into car
if you pull firmly on the door it will allow the glass to get by the weather stipping for you guys with pre 2005 cars (who find this funny) when you pull the door handle the window drops about a half inch when you close the door it raises a half inch in to the weather strip for an air tight seal really kind a trick and makes the car air tight
If for some reason you actually cant get into the door.
Try putting they key in the trunk and opening that because I am know that one can be manually opened with a key. Then crawl in there an fold down the seat, you probablly can't fold the seat down because the battery is dead.
the key for my 1995 won't unlock the door.. if my battery dies or key fob decides to not work i have to crawl thru the trunk. the key WILL unlock the trunk, but not the door.. grr.. had to crawl thru the trunk on a date. lol
