help!!1!1!1
Old Aug 31, 2008 | 06:23 PM
95GTbanana's Avatar
95GTbanana
Default help!!1!1!1
this is my first pony..so im doin brakes today on the front..i have a 95 gt...when changing pads do i take the whole setup off or justthe caliper and leave the bracket on?
Old Aug 31, 2008 | 06:52 PM
Stepman's Avatar
Stepman
You can leave the bracket if you are not turning the rotors. Just pull the cal., push the piston back in with a C-clamp, and put in new pads. Don't forget to pump the pedal a few times before you start it up and put in in gear, or you are in for a little scare.
