question about 351 engines
Old May 16, 2005 | 11:57 AM
xjarhead1999's Avatar
xjarhead1999
Default question about 351 engines
ok bear with me if i sound stupid here or it takes me a bit to answer anything i left you that you need to know for answers. this is for a guy at work and i didnt know what all i should ask him before i posted.
anyway his goal is to put a fuel injected 351w in his project car. i think he is going to stroke it to a 408. he has read that for the fuel injection he can use a computer, wireing harness, maf, tb(everything you would use to convert to mass air) from an 89-93 5.0 mustang. is that correct? would he need a chip to get it to work right? i know the intakes would be different, i think trick flow makes them for the 351. next question is what would be a good donor to pull a 351 block from? he said something like some are not designed to use roller hydraulic cams and some do.
thanks for any help
Old May 16, 2005 | 12:01 PM
C/Note's Avatar
C/Note
I ♥ Acer
Default RE: question about 351 engines
you will need a 94 block had ,set up for hyd roller cam ..thats what my block is below...but i got solid roller in it ...as for as intake ,and that sort of stuff ,,i dunno . im a carb man ....[&:]that block is out of a 94 f350 truck
[IMG]local://upfiles/10419/A6DC9658DD8745B2A23F647BBD1A295A.jpg[/IMG]
Old May 16, 2005 | 02:17 PM
1990silverlx5.0's Avatar
1990silverlx5.0
I believe fron 92 to 96 broncos use the 351 roller cam (I have a 96) as far as the computer goes theyre the same as the 5.0 but i believe the only difference is the mass air is calibrated for 24lb. injectors as well as having the matching 24 lb injectors. I do know that the factory specs for my bronco (Hp and Tq.) are actually a little lower than my 90 mustang it's only rated at 215 HP I think it might have a little more Tq but if it does it's not much
Old May 16, 2005 | 11:03 PM
mkspeed26's Avatar
mkspeed26
yes it is all the same. he will need to upgrade all of the mechanical stuff and get it computer tuned, but it will work
steelers743
Aug 31, 2015 07:16 AM
movielover40
Aug 27, 2015 10:13 PM
Mustangs of Illinois
Aug 22, 2015 10:00 PM
HIS S-197
Aug 10, 2015 05:47 PM
89blueslug
Aug 10, 2015 07:20 AM
