spec stage 1 clutch issues..
Old Sep 5, 2008 | 04:16 PM
02oxfordwhiteGT's Avatar
02oxfordwhiteGT
Default spec stage 1 clutch issues..
i recently installed a spec stage one clutch kit and a frpp tob. I have 600 miles on it so far and it still vibrates and chatters. its not as bad as when i first installed the clutch. should i give it more time to break in or do you think i could have an issue? clutch pedal is adjusted correctly and i have adjustable cable, quadrant, and firewall adjuster. any input would be appreciated it thanks.
Old Sep 5, 2008 | 10:50 PM
OnyxCobra's Avatar
OnyxCobra
by 600 miles the clutch should be fully broken in. Were you easy on it at first? Did you get the flywheel resurfaced when you installed the new clutch?
Old Sep 8, 2008 | 01:42 PM
02oxfordwhiteGT
i was really easy on it. never slipped it. flywheel resurfaced, it shifts perfect and strong, no slipping no grinding in any gear but first and rev are still chattering and vibrating a little bit. i loctited all flywheel bolts torqued down to specs and everything. i dont understand it. i may have to redo it but i will give it more time first.
Old Sep 8, 2008 | 04:55 PM
BlackMage's Avatar
BlackMage
dont redo it, its the way specs are. honestly it took about 1000 miles for my chatter to go away. all is well now. and it only does it from a stop, or when your downshifting right? it feels like the whole car wants to fall apart and everyone looks at you like you dont know how to drive stick right lol. i think mine was actually a small imperfection on the flywheel which caused the chattering. but specs are known for chattering quite a bit. give it another couple hundred iles it will get better.
Old Sep 8, 2008 | 07:14 PM
02oxfordwhiteGT
thanks dude. i was ready to drop it all out again. lol yeah its only in first and a tiny bit barely on downshifting. all else is good. ill wait it out. thanks for input
Old Sep 9, 2008 | 10:18 AM
BlackMage's Avatar
BlackMage
yea no problem man. i was ready to pull mine out too, but it just was gonna be way to much work all over again haha.
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
Thunderball
15
Nov 22, 2015 11:49 PM
junior04
Sep 28, 2015 10:53 AM
Sep 25, 2015 09:06 AM
