2003 v6 sonds like belt squeking or something
Old Sep 19, 2008 | 06:10 AM
biomedtech's Avatar
biomedtech
Default 2003 v6 sonds like belt squeking or something
I'm a 1rst timer and need some help. My wife has a 2003 v6. when starting it up this morning a fairly loud squeak came from the front and bottom. sounded like a belt or pulley? but it would not crank over. had her try it again, same. she tried 1 more time and it started, with the same loud squeak. it idled for about 15 - 20 seconds and the squeaking sound started quieting down quickly. appx. 20 seconds later it was almost silent and she went to work. this same thing happened wednesday but it wouldn't crank over and it was towed to a shop. they found no codes and could not duplicate. tghey kept it overnight and cold started and heard the noise themselves, but it would crank. they couldn't find the culprit and it was no charge. and said to bring back if it happens again, which we will after work today. Any help would be greatly appreciated. I thank you all for your time/help/knowledge.
Old Sep 19, 2008 | 05:04 PM
LilRoush's Avatar
LilRoush
I'd look a pullies and when it wouldn't turn over... was it batt/alt related? Might have some belt slip due to a bad tension set up as well.
Old Sep 19, 2008 | 09:17 PM
khooper's Avatar
khooper
Just replace the belt, its inexpensive. If you're looking for something to 'cover up' the noise like spraying a lubricant on them than, expect yourself broken down on the highway.
__________________________
Check out this: Tough Country
Old Sep 20, 2008 | 01:06 AM
UTI_TECH429's Avatar
UTI_TECH429
first off is it cold outside when you start the car?
pcs
Aug 27, 2011 07:09 PM
Leeiswho2b
Jun 8, 2010 12:07 PM
stang2004
Mar 13, 2009 09:11 AM
stang2004
Nov 19, 2008 04:36 AM
NITROSTANGRACING
Mar 20, 2006 11:00 AM
