Power Window Problem
Old Sep 20, 2008 | 11:21 PM
sgt0704's Avatar
sgt0704
Default Power Window Problem
i've done a search, but havent found anything that helped.
i have a 94 5.0 and the power windows don't work. and the power locks don't work. when i push the switch (drivers or passengers) they make a low washing machine type noise. but they don't go down or up...
could this be a relay problem?
Old Sep 21, 2008 | 01:41 AM
UTI_TECH429's Avatar
UTI_TECH429
yes check the relays if not those its possible the motors bad but hard to tell when i cant hear the noise.
Old Sep 21, 2008 | 07:52 AM
ewgoetz's Avatar
ewgoetz
could be a issue with the Drivers side switches for the windows and locks.
Old Sep 21, 2008 | 11:22 AM
sgt0704's Avatar
sgt0704
I get the same problem with the passenger side switch as well.. it's an intermittent pulsing sound... almost like a washing machine sound as it goes into the spin cycle... (best way i can describe it.) i would think if the motors were bad.. they'd either go down slowly, or not work at all..
Old Sep 21, 2008 | 05:24 PM
sgt0704's Avatar
sgt0704
even if i'm getting the same results from the passenger side switch?
Old Sep 21, 2008 | 11:05 PM
UTI_TECH429
well its not the switch because you would hear nothing if the switch and relay wernt working i would check the wireing to the motor as well as the connectors your prbably not getting enough voltage to the motor or have high resistance in the circuit somewhere. wiring diagrams are a big help with electrical problems
Old Sep 22, 2008 | 06:12 AM
ewgoetz's Avatar
ewgoetz
corosion in the switches are a good source of resistance and on the SN95 stangs if you dont have the windows up when its raining the the water will drip right into the switches. I had to replace mine a while ago cause the locks had that kind of issue where the motor locks werent locking instantly. not to mention they are cheap to replace vs a motor.
Old Sep 22, 2008 | 09:58 PM
sgt0704's Avatar
sgt0704
Fixed.. the problem was the motors. figured it out by pushing/pulling on the window as i hit the switch...
thanks for the replys.... now on to the power locks not working....
Old Sep 22, 2008 | 10:00 PM
UTI_TECH429
lol no problem
Old Sep 22, 2008 | 10:01 PM
UTI_TECH429
do you here anything when you hit the lock or unlock switch?
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
movielover40
Aug 27, 2015 10:13 PM
HorsePower99
Aug 26, 2015 11:29 PM
