tail/brake light brightness, help
Old Sep 22, 2008 | 08:18 PM
rdndrty's Avatar
rdndrty
Default tail/brake light brightness, help
One of my brake light bulbs is not working properly. It turns on partially for the tail light, but does not get brighter when I hit the brakes. Is this a wiring problem, or a bulb problem? Appreciate the help.
Old Sep 22, 2008 | 09:04 PM
UTI_TECH429's Avatar
UTI_TECH429
start with the bulb replace it cuz i think its like less then 5 dollars and if that doesnt fix it you probably have a bad connection somewhere or high resistance in the circuit
Old Sep 22, 2008 | 11:54 PM
Blckstng93's Avatar
Blckstng93
Check the filament in the bulb as the brake and taillights have a dual filament in them. One filament is for the taillights, and when you hit the brakes, the other filament lights up, resulting in a brighter light. My 93 had that problem. One of the filaments burned it itself out.
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Explosive
Oct 2, 2015 07:45 AM
ChampInSD
Oct 2, 2015 04:55 AM
