synthetic or conventional
Old Sep 23, 2008 | 12:50 PM
MkRoxy03's Avatar
MkRoxy03
Default synthetic or conventional
Whats the best oil for mustangs? i bought it my first mustang about 4 months ago and its time to change oil, i got a K@N oil filter for it, just need to know what oil would be Best!
Old Sep 23, 2008 | 01:53 PM
Mustang_Joe's Avatar
Mustang_Joe
synthetic oil. I hear it makes your engine last longer than it would with the other oil and frees up a little rwhp.
Old Sep 23, 2008 | 01:58 PM
UTI_TECH429's Avatar
UTI_TECH429
i would run synthetic but if the car has been run on conventinal for a long time run it on conventinal, alot of the conventinal now is just as good as the synthetic though, you will get ppl who love synthetic and tell you to use nothing else then you will get the ppl who love conventinal and tell you different, but synthetic releases heat better as well as lubricate components better, like i said if its been run on conventinal for a long time and you dont feel like cleaning the engine out just run it on that
Old Sep 25, 2008 | 11:52 PM
Jfsram's Avatar
Jfsram
Synthetic is better but it comes at a large cost.
Old Sep 26, 2008 | 03:56 AM
WhiteSN95's Avatar
WhiteSN95
If your car has alot of miles on it (Say around 75,000miles), then you should probably stick with conventional. High mileage engines should not be shocked into using synthetic.
Also, are you sure about what oil the previous owners used? I'd check that first.
Old Sep 26, 2008 | 06:19 AM
GreyStang's Avatar
GreyStang
I go 1/2 way & use semi-synthetic
Old Sep 26, 2008 | 08:15 AM
Timspony's Avatar
Timspony
SVT Section Moderator
semi-synthetic a waste of money...most oil's only have about 15% synthetic added to the blend...
I'd use Mobil 1 Syn. oil with the K & N filter ...
Old Sep 26, 2008 | 08:31 AM
FixFalcon's Avatar
FixFalcon
I switched my Probe over to full synthetic at around 100k miles and it's never run better.
Old Sep 26, 2008 | 10:05 AM
Mudflap's Avatar
Mudflap
You will never notice a difference. Run whatever you feel comfortable with. I've tried it all over the years, and I have no evidence that running any particular type of oil has ever led to the downfall of any of the 20+ cars I've owned.
Old Sep 26, 2008 | 01:31 PM
DannyStyle22's Avatar
DannyStyle22
Banned
I remember reading an article awhile back I ll see if I can dig it up about the factory oil filter being the best one on the market. So I would recommend Mobil 1 (5w-20 is what the mach takes) and the factory filter
