Ticking noise at idle?
Old Sep 24, 2008 | 02:46 PM
pallidamors's Avatar
pallidamors
Banned
Default Ticking noise at idle?
So about 4 months ago I bought a 2001 ford focus with 63k miles. WHen I got it I did a full tune up and fluid change. I just did my 2nd oil change on the car since Ive had it and now when the car idles there is a slight ticking noise. As the rpms increase the noise goes away. Any ideas as to what it might be?
Old Sep 24, 2008 | 04:39 PM
DannyStyle22's Avatar
DannyStyle22
Banned
I am not trying to insult your intelligence but, did you check the oil level? If everything is good there... Is it primarily when the vehicle is cold? Also did you change to a different type of oil or oil filter?
Old Sep 24, 2008 | 10:48 PM
UTI_TECH429's Avatar
UTI_TECH429
it sound like you have a bent valve if it is a slight ticking noise coming from aroud the heads normally a valve. either that or spark knock depending on the sound and the way it runs, but mostlikly bent valve.
Old Sep 25, 2008 | 09:12 AM
DannyStyle22
Banned
thats a possibility but imo getting way ahead of ourselves. It could be a million things just seems kinda fishy that is happened right after an oil change. Start with basic diag and work your way from there.
Old Sep 25, 2008 | 09:22 AM
Chopper's Avatar
Chopper
A new noise in a newly purchased car right after the oil has been changed HMMMMM?????
Could it be that the seller added a thickening agent (STP,Lucas,etc.) before the car was put up for sale? It's been done before!
You might try using a high detergent oil for a few miles to clean the problem out or you could add some STP to the oil to see if the engine quiets down.
Old Sep 26, 2008 | 10:11 PM
pallidamors
Banned
This is the 2nd oil change I have done on the car. After the first one, everything was fine. Just to clarify...it is a slight ticking/knocking sound at idle, but once the rpms rise it goes away. Im no expert, but if something was bent wouldnt the noise get worse with higher rpms?
Old Sep 26, 2008 | 10:19 PM
UTI_TECH429
not really because that normally indicates excessive wear between the lifter body and its plunger, this noise could also be caused by low oil pressure, or too thin of an oil
Old Sep 26, 2008 | 10:27 PM
pallidamors
Banned
but why would it go away as the engine revs?
Old Sep 26, 2008 | 10:43 PM
2000Stanglover's Avatar
2000Stanglover
I have the same problem on my mustang. its been doing it seance i got the car.
Old Sep 27, 2008 | 10:14 AM
UTI_TECH429
because the valves are under load when you hit the gas and the valves move faster so the ticking goes away. when a valve is under load like that it cant make the ticking noise.
